1 - 18 of 18 Posts
Retired Reviewer
Originally Posted by BakingSoda View Post
Sure is! 1.4V and got her up to about 4.13 http://valid.canardpc.com/show_oc.php?id=1401386
anyone got a linky to the 4ghz club?
I think he was asking if the 4.4GHz was stable. We can all post numbers like 4664 or so:
But you will note that your rig is stable at 4.13GHz, not 4.4.
It's stable, ran 4 rounds of 3dmark06 and played L4D for a few hours. No glitches, shutdowns,ete.
that means nothing lol.. you need to run a stress/stability test like p95, occt, ibt, linx, etc
Why isn't your Vcore showing up? Too bad you don't have HT enabled, that would have been promising.
Nice overclocking there, but.....
.... that doesn't mean you're stable (no offense). 3DMark06 and games won't really test your CPU for "full" stability; you can't be very sure that way. It's generally accepted that you run at least 8 hours Prime 95/Orthos, and 50+ rounds of LinX/IntelBurnTest doesn't hurt either. You could also try OCCT.
Discussion Starter #14
Originally Posted by SecrtAgentMan View Post
Temps?
40C idle
around 60C load
I'll run prime95 overnight, and try to enable HT.
Take note of your ambient temperature if you can. Load temps don't mean much without ambient temps.
Discussion Starter #16
It's a nice cool 60F (I live in the basement!)
1 - 18 of 18 Posts
