1 - 8 of 8 Posts
looking at building new system
would like sum advice as this will b my first build and overclock
i5 2500k
ocz vertex 2 180gb ssd
cooler master 690 2 advance
2 x 4gb corsair pc 12800 vengance series ddr3
windows 7 pro
western digital green caviar sata 2 1TB 64mb cache
looking at either evga gtx570 overclock or evga gtx580
looking at either asus sabertooth p8p67 v3 or asus p8p67 prov3
power supply lm unsure as l do wish u overclock cpu to a mild 4Ghz and will run sli in furture
not sure on cpu cooler heaps to b so many to pick
any help would b great
· Old to Overclock.net
1) Caviar black over the greens, more reliable and dang faster (waaaaay faster)
2) Have you ever looked at the raven (Silverstone) rv02, much better than the 690
3) A seasonic or corsair 650/750 series (silver rated or gold rated) PSU would be good for your rig.
Video Card: Doesnt matter, its up to you, 570 and 580 are both good cards. You choose.
Motherboard: I would go with the Sabertooth if possible.
Power Supply: I would get a quality 750w or 850w PSU. Corsair and Seasonic both have good models.
Anybody have any idea how large the following cards
are
-asus gtx580 direct cuII
-gigabyte gtx570 overclocked windforce x3
-gigabyte gtx580 windforce x3
The two gigabyte cards l havnt
been able to find very much about in the way of reviews gigabyte site has nothing abouy
size of the cards on there is it true the asus is 11 x 5 inch? Would l b able
to run any of
the above cards on a asus p8p67 deluxe board in sli?
Would this fit in cm690II advance case?
are
to run any of
If you are looking at getting a 580: MSI just released their lightning series: http://www.newegg.com/Product/Product.aspx?Item=N82E16814127579&cm_re=MSI_GTX_580-_-14-127-579-_-Product
And yes: the P67 Deluxe does support SLI
As for the case: I think you will be fine.
Originally Posted by dazla27;13117582
Cant get the msi card as lm in australia dnt think its out here yet
wat l ment was is the pcie slots far enought
apart to run sli asus gtx580 direct cuII on the asus deluxe p8p67 board?
You could sli those, but I am warning you those are HUGE cards. I have the Asus GTX 570 directcu 2, but far as cooling goes it stays cool...really cool.
1 - 8 of 8 Posts
