1 - 13 of 13 Posts
Overclock Failed...
You'll be much happier than you can imagine!
By the '80's they pretty much had transistors figured out.
Overclock Failed...
Originally Posted by MystKid
so you are saying that this is a good piece of hardware?
Yes, though the Marantz name engenders some added (unnecessary) cost.
Pioneer, Rotel, Yamaha, etc will sound as good for less.
Buy used. I just bought a Marantz SR7400 for $67 including shipping on ebay.
Laptop Gamer
Originally Posted by MystKid;15206654
hello guys i am looking fo r an amplifier fo ra home stereo. i am looking at this one:
MARANTZ 2220B
its a vintage amplifier and it is supposed to be pretty good. any of you know/have it?
forgot to say budget is 250 Euro. also need the speakers. in total id liek to spend 500 for speakers and amp
Depends what they are asking. You may have to end up changing out leaky caps, and that is a serious pita. The "vintage" solid state stuff is so far superior to modern offerings (sound and power wise) that it's hard to believe we once could make stuff sound so good (and rate the power output accurately) But, it DOES have to be maintained every so often. I say "listen to it if you can". If not, ask the seller for a buy back guarentee...(just in case it something is the matter). Good luck, bro.
1 - 13 of 13 Posts
