im looking for a decent bluetooth headset for under 30$ it dosent need to be great but comfortable for about a half an hour and work on ps3
thanks
thanks
can't get one the won't make you sound like you are in a tin can or wind tunnel for under $30, I suggest doubling your cost and get a plantronics or a jabra headset with noise canceling. I have the Plantronics Pro and it works great. I drive a '92 dodge van and can leave the windows down and hold a conversation just fine.Originally Posted by nicholasmorisi;15207732
thanks
IMO, I don't like LG that much. I have had a few different products and I can't say I liked any of them. They are typically a mid range, at best, company and, just from my experience, their high end is almost entry level in other companies product lines. I have had a few different Plantronics ear pieces and haven't had an issue.Originally Posted by nicholasmorisi;15229356
thank you i will keep that in mindwhats your opinion on the lg hbm 235 with noise reduction![]()
