1 - 4 of 4 Posts
An OC'd 3930k at 4.7 GHz can get upwards of 180 GFLOPS using linpack. The easy was to run it in Windows is through the Intel Burn Test (IBT). 57 for you CPU seems about correct though I don't know the exact figure, as it will vary depending on the program you use to measure it. Programs that don't use AVX (advanced vector extensions) will get around half the FLOPS as ones that do.
1 - 4 of 4 Posts
