Looking for a good wireless controller for PC
1212 Views 30 Replies 20 Participants Last post by  CravinR1
I'd really like to get a wireless controller for my htpc to play emulators with. Any suggestions? I will be playing a couple of light computer games. So something with a good D pad and joystick. Also, I'm sort of on a budget... So less than $40 please... Used on Amazon works too. < $30 is a plus.
Thanks!
Also, if this belongs in peripherals, I am sorry.. Please move.
1 - 20 of 31 Posts
oh this is easy, buy the wireless reciever for xbox 360 controller off newegg.com
http://www.newegg.com/Product/Produc...82E16874103054
as for emulators, the Dolphin Wii/GC supports x360 controller from the get-go, others require xpadder keyboard emulation.
http://www.xpadder.com/
if you want PS3-style controllers that will be recoginized as xbox 360 controllers, here:
http://www.logitech.com/en-us/gaming....ac=bc|713|288
you can probably get a xbox360 controller with wireless USB receiver for relatively cheap
EDIT: I didn't look around too much on Amazon, but a quick search found this:
http://www.amazon.com/Microsoft-Xbox-Wireless-Controller-Windows/dp/B002TIW7OI/ref=sr_1_11?ie=UTF8&qid=1302157756&sr=8-11 http://www.amazon.com/Microsoft-Xbox-Wireless-Controller-Windows/dp/B002TIW7OI/ref=sr_1_11?ie=UTF8&qid=1302157756&sr=8-11
I agree with the other two poster, the 360 wireless controller is top notch.
360 wireless controller for PC
Emulator references are against ToS and will get you infractions
yes the 360 wireless controller for windows is perfect, nice comfy design and solidly built.
Well that's frustrating... Since I hear people talk about them all the time.. Changed the OP. Thanks for the heads up.
Thanks everyone for the advice! Seems like I'm going to go with the xbox dongle! +rep to all!
I'm in need of a controller too for my htpc...lemme know what you end up getting.
Sent from my SCH-I500 using Tapatalk
I use my ps3 controller paired to my pc by a bluetooth adapter I got at best buy. Grab motioninjoy drivers which were recently approved by microsoft and got a signature so you can load the pc in normal mode and play with them from the start.
Posted from my Motorola Atrix with Tapatalk
Another vote for the XBOX 360 Controller.
If you need to save some money I suggest a knock-off USB receiver and get a used wireless 360 controller, I have two of the no-name receivers and they work as well as the real one I use with my HTPC.
The best part is that they are less than $12 each: Link to $12 Xbox 360 Wireless Controller Gaming Receiver
Hope that helps you out!
Talking about them is definately frowned upon. Linking software/instructions for breaking copy protection is a big no no
I would also recommend the xbox controller. Mine isn't wireless but it is an awesome controller.
NO DONT DO IT NOT XBOX CONTROLLER!
here use DUALSHOCK 3
Originally Posted by StormXLR;13009675
use motioninjoy . Its really nice free third party software , easy to configure and install, great customer support!
http://www.motioninjoy.com/
and get my high res icon here
http://forums.motioninjoy.com/viewtopic.php?f=65&t=1400
if you have any questions just ask
360 controller, I have one it works great, plus most of the games coming out today seem to be already configured to use the button mappings on the 360 controller.
What I would like to know, is there a wireless controller for the PC that is like the PS3 controller, where you recharge the controller by plugging it to the system. I do not like the idea of the changing batteries the whole time.
Basically, a rechargeable battery inside the controller is what I am looking at.
Yes, they are called Play and Charge batteries. It's a battery pack that is rechargeable, and you charge it by plugging a cable included with the pack that plugs into the USB of the 360 and the port on the top of the controller.
I would also like to find where I can buy a wireless receiver for my wireless controllers. NewEgg has them deactivated
There is a USB charger for the 360 that goes into your system, but it doesn't carry the signal so you still have to have the wireless receiver attached
1 - 20 of 31 Posts
