1 - 2 of 2 Posts
Hey OCN,
I'm in the market for some new monitors. I'm undecided if I'm going to get a dual monitor or triple monitor setup, basically comes down to the overall cost.
What I'm looking for:
required:
- 20" - 23" screen
- Vesa mountable
- 1080P resolution (or higher)
Preferred:
Has the sensor which automatically adjusts orientation between landscape and portrait when the monitor is rotated 90 degrees.
My primary use of the monitors will be for school and office work. I'd like a 3 monitor setup so I can have one monitor for MS office, one for internet, and one for E-book. The E-book is the main reason why I want one with the rotation sensor. I'm not opposed to buying one nice monitor and 2 cheaper ones if there's a significant price difference. I live in Canada so preferred sites for recommendations are ncix.com newegg.ca and amazon.ca
Side note: I also game occasionally, but I can't afford to buy top end monitors. I'm looking for the best value for the money.
These are a few I've looked at so far, but i'm a bit out of the loop when it comes to monitors. Any feedback would be appreciated.
http://www.ncix.com/detail/benq-gw2255-21-5in-widescreen-led-70-79926-1383.htm
http://www.ncix.com/detail/lg-22m35d-21-5in-led-display-a5-98969-1261.htm
Edit - Found this one too:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16824260227&AID=10657534&PID=3938566&SID=&nm_mc=AFC-C8JunctionCA&cm_mmc=AFC-C8JunctionCA-_-na-_-na-_-na&utm_medium=affiliates&utm_source=afc-%zn
1 - 2 of 2 Posts
