looking for a motherboard and cpu
771 Views 16 Replies 6 Participants Last post by  Zerogamer22
hello. anyone know any better motherboard with ATX type? and cheap too
1 - 17 of 17 Posts
Are you looking at sticking with AMD or swapping to Intel? What's your budget?
yeah i'm planning to upgrade my system.. and i would like amd motherboard too..under 100. i'm using ecs neforce 3 a. it's time to upgrade.
hmm a combo deal is not bad. anyone suggest or have it? lol
Well, you're not really going to find an upgrade for your system.
They don't make parts anymore, but Ebay would be your best bet.
I suggest looking for the DFI LANParty NFII Ultra B
So do you want to keep your current CPU and upgrade the motherboard for under $100? Or are you looking to upgrade both CPU and motherboard? Like Tator Tot said, it's going to be fairly difficult finding a motherboard that will work with your CPU. Also, if that's original DDR RAM (not DDR2) you're going to struggle to find a compatible motherboard.
Might I suggest increasing your budget a bit and getting a new motherboard and CPU (and perhaps RAM)? There are plenty of websites where you can find great Mobo/CPU/RAM combos.
EDIT: Take a look at the Newegg combos page.
allright. 200 around. motherboard and cpu,ram.
nice pick!
i like this one
i like this one
I think its a lovely deal, you'd need to pick up some form of heatsink though.
The OEM version of that processor included doesn't come with one.
Although you will feel a major performance voast than with ur current build.
all right I'm gonna pick some better heat sink fan or cooling system for oc.
sweet! whoa. it look nice.
1 - 17 of 17 Posts
