Looking for a Motherboard tray
375 Views 7 Replies 3 Participants Last post by  Shadows Renegade
title says it all, im looking for a removable motherboard tray, aside from buying a case with one installed, ive been having rather bad luck finding anything that would work.
i dont want to drop 100+ on a case with a removable tray if i can find one elsewhere.
i have an e-atx motherboard im trying to mount. the reason i need a tray is im building a plexi case and plexi is way to prone to static, i would prefer to find something i can ground out, just incase.
thanks in advance, hopefully somone has an idea on where i can buy something, or may even have one i could buy off them. for reference i live in canada.
1 - 8 of 8 Posts
thanks juggalo, any idea if they ship to canada before i go ahead and try to order, the aluminum one looks perfect.
Well I was going to say look at Cooler Masters Site, they have just motherboard trays there for pretty cheap (around $15-20), but shipping is around $20 to Canada.
shipping isnt an issue, thats a tax write-off, i work as a self employed computer tech. so i just need to worry about what the part will cost me.
Ahh, well then they have 2 on their site, both less than $20 (+ shipping).
Yes I believe that they do ship to Canada.
probably going CM its cheaper after shipping the the others, and i dont want an acrylic tray due to the static or id go with puget. thanks guys + rep for ya both.
1 - 8 of 8 Posts
