Looking for a New Case.
317 Views 6 Replies 4 Participants Last post by  IamRolks
I am currently looking for a New Case.
I have a Raidmax Smilodon, I've had it under a month.
I just want something that doesn't have a Front Cover, I want the DVD Drive to just be there without having to open a door.
I am Currently Looking @ The Antec 900.
I can Probably get it for 60-65 Used.
What other Case would you guys recommend?
Or should I just get the Antec 900?
I find it pretty Cheap and I like the look of the Case itself.
Would it be wort it upgrading from my current case to the 900?
1 - 7 of 7 Posts
Fry's is selling the Antec 300 for $44 shipped, could also look at the CM590 or 690 also.
Is there much Difference between the 300 and the 900?
the antec 900 would definately be a good chioce, i got rid of my smilodon for a antec 1200 and i love it.
take a look at the cm690/antec1200.
If you're in the US, the cm690 can be had for under 50 bucks refurb'd from their online store. I dig it. Great case.
its a smaller than the 900 but it doesnt have a window. 2 120mm fans in the front, 1 120 on the side, 1 120mm on the back and a 140mm on the top. Antec 900 has a 200mm fan at the top
Used Antec 900 for $60. Should I buy it?
Its a Local Sale.
I don't know what I would do with my Smilodon though.
1 - 7 of 7 Posts
