1 - 3 of 3 Posts
i just dont know what one to get i all way been a evga guy
but the p67 is not out yet.
i know i want the best one for overclocking and i have 2 gta 480s
asus has some cool apps like there level up. but dose that realy work
and is it stable.
any way if you were going to buy a p67 board to day what one would you get
and i will be geting the 2600k cpu.
Do you have a budget or is it just whatever one works the best?
Im also curious why you are upgrading from a 920 to sb...
lAptOp jUnKie
and is it stable.
CLICK HERE and you will see links in the very 1st post for P67 mobo reviews. This will help you decide what to buy for yourself. All the reviews are not listed so you can also Google one of those mobos and you will see additional reviews to read over. Hope this helps
If your budget has no limit, check out Sin0822's P67A-UD7 Most In-Depth Preview/Review!!
and you can also Google that mobo to see more reviews.
And you can check out this article by bit-tech.net...The Best Memory for Sandy Bridge
1 - 3 of 3 Posts
