1 - 20 of 48 Posts
I've been looking around and find it difficult to find a case that meets my criteria. I want very clean, black, look on the exterior. I don't want any windows or fan holes or anything. The closest I've been able to find is the Lian-Li PC-A71F, but the top door kind of ruins it. Said case is also at the top of my budget.
EDIT: I even plan on using a USB optical drive with my new build. I also don't plan on trying to break any overclocking records, so there won't be much heat.
1 GTX 460, Phenom x6 1055T, CM V6GT or H50, ASUS Crosshair IV. I think it'll be a sexy build lol
This is a great little case. The PC-B10 is about as clean as it gets. It does have a very small door on top for usb and headphones. Almost impossible to find a case without something like that now, either on top, or in front.
Discussion Starter #5
I already looked at the P180 and P190 series Antec's, but didn't quite like what I saw.
If you look at my siggy, you'll see I already have a Whisper lol
I'll look at the PC-B10; Am I correct to say it's got a clean top too? I can't find any pictures of the top of the case.. Which I'm beginning to realize is quite hard for any case lol
48" Mousepad Extremist
Yeah if the shipping doesn't kill you, look at the Fractal Define R3.
Discussion Starter #14
The Silverstone ft02 has that ugly external USB door and fan grill on the top of the case, sorry; Fractal Desaign R2/R3 have side fans. I really think the closest things to what I'm looking for are from Lian-Li, the PC-B10 and A71F are my top choices right now.
Thanks, again
Also, the 600t has those handles and the dial and all that nonsense lol
EDIT: I don't mind idling a little high. I idle between 35 and 40c right now and I'm ok with it. My PWM fans have a very aggressive acceleration ratio above 48c - I pretty much go from max low speed to full bore in 8-9c.
Good luck cooling it then. The fan grills are there for a reason.
I had a case like the one you're suggesting. No fan grills, just a solid chunk of steel with a rear 120mm fan. It was an oven. You aren't going to get anything resembling a decent overclock in a case like that. You're temps are probably going to be 10c higher than normal.
PC Gaming 1337 Enforcer
Thanks, again
Get the PC-A71F. Great case and it can cool well too, not that you need more than it's stock cooling.
Discussion Starter #17
I have a NZXT Whisper right now and I'm certain any Lian-Li cools better than this thing.
Also, could anyone tell me why the A71F costs less than the B10? Isn't the B10 a mid-tower and the A71F a full tower?
No idea. Usually the PC-B series denotes hotswappable hard drive bays, but it doesn't have any.
Honestly I recommend this case, it is ridiculously beautiful and clean:
http://www.performance-pcs.com/catal...ducts_id=21766
If you don't like the blue light, you can keep it unplugged and paint over it easily.
1 - 20 of 48 Posts
