1 - 4 of 4 Posts
Ok i've searched and searched and searched... and searched some more.<br />
<br />
<a href="http://www.thermaltake.com/product/DCfan/LEDfan/thunderblade/thunderblade90/thunderblade90.asp" target="_blank">http://www.thermaltake.com/product/D...derblade90.asp</a><br />
<br />
I'm looking for the blue led 90mm A1911 Thunderblade on that webpage. (I don't want the one with adjustable speed.)<br />
<br />
I've even emailed thermaltake and they never responded. I'm in the USA, all the sites I find that have that fan are in russian or UK.<br />
<br />
Anyone know where I can get this fan in the USA?<br />
<br />
Thanks.
Discussion Starter #2
Bump..<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16811999125" target="_blank">http://www.newegg.com/Product/Produc...82E16811999125</a><br />
<br />
Found this but its the 80mm version =/<br />
<br />
I'm looking for a fan to replace the 2 90mms in the armor, doesnt anyone have any idea what the DB and CFM of the 90mm fans that come with the case are?
lol i googled it and the first thing that came up was this thread.<br />
<a href="http://www.pcandparts.com/howorder.htm" target="_blank">http://www.pcandparts.com/howorder.htm</a><br />
they have it here.<br />
This is the fan, i think the last thing is the part number.<br />
Thermaltake Thunderblade Fan A1911 90MM 90CM for Case 12V $8.00 z-57
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16811999121" target="_blank">http://www.newegg.com/Product/Produc...82E16811999121</a><br />
<br />
A lot of people get these. <br />
<br />
I will say it is usless to replace those two fans. As hardly any warm air gets to the top, and if it does the holes for the fan there are so small it does nothing. And the rear HDD one just pushes HDD air and thats really it. But if you MUST replace just replace the rear one and remove the top one as all it does is collect dust.<br />
<br />
pink
1 - 4 of 4 Posts
