1 - 4 of 4 Posts
In the market for a Z77 motherboard because I'm finally upgrading from my Q9650.
Two main requirements for the motherboard:
-Delivers stable 24/7 maximum overclock
-At least 8 sata ports, preferably 10 though ( tons of 1Tb drives )
I do not care about CFX-SLI capabilities past two cards. So if a motherboard supports 4x SLI / CF that's great but not a deal maker.
Right now I've narrowed down my choices to two motherboards
ASRock Z77 OC Formula - 10 sata ports and great for overclocking.
GIGABYTE G1.Sniper 3 - 10 sata ports and also great at oc.
Another option is GIGABYTE GA-Z77X-UD5H. I have no idea what the difference is between the regular UD5 and UD5H though.
My price range is $180-$250.
· Premium Member
There is no regular UD5 for Z77. There are WB and non-WB versions that differ from the fact that first has WiFi module.
G1 Sniper 3 supports 3/4-way SLI whereas OC Formula doesn't. It also has Creative codec, and Killer NIC.
UD5H and G1 Sniper 3 have the same VRM. OC Formula has slightly better mosfets, but both boards are more than capable for any 24/7 OC anyway.
Reactions: DeadSkull
Alright so if I do not care about 3/4 way SLI or CF then UD5H is just as good as G1 Sniper in terms of overclocking?
· Premium Member
Yea. It just has extra features. Usually I recommend UP5 over G1 Sniper 3 in that price range since it is better for OC, but it doesn't have enough SATA ports, but it has Thunderbolt instead.
1 - 4 of 4 Posts
