1 - 2 of 2 Posts
I'm looking to buy a used/refurbed notebook for my daughter. Homework and light gaming. I'm a desktop guy, I don't know a lot about mobile gaming GPUs, so I could use some advice. The main question I have, is for my budget range, what type of CPU/GPU combination should I be looking for? 770m/780m? Newer? Older?
Thanks in advance.
What is your maximum budget? $300
What country are you in? US
What will be the uses of this laptop? General use/light gaming (web games, older games like Halo)
Do you have brand loyalty or care which brands we select for you? No
What screen size do you require? Open
What screen resolution do you require? Open
Are you looking to buy NEW or would refurbished/recertified/used be okay? Used is great
How long should the battery last? (Under optimal conditions, no movies/games/heavy internet) Open
What games would you like to play with your laptop? And on what settings? Older FPS type games like Halo,
What operating system do you need? (if any) Not needed, will install W10
Is there a certain style of laptop you want? (aluminum, black, gaming, etc.) No
How much hard drive space do you need? Open
Do you need any special hardware? (blue ray, webcam, specialty ports, etc.) No
Is there anything else we need to know? Nope, thanks!
1 - 2 of 2 Posts
