1 - 1 of 1 Posts
Random Eventer
Watercooling Components were run with distilled water with silver kill coil (of which I would be adding in with the res) with teal dye.
Swiftech MCP655-B Pump
AlphaCool XT45 120mm rad
XSPC Raystorm CPU Block with both Intel and AMD hardware
PrimoChill PrimoFlex Advanced LRT 1/2in.ID x 3/4in.OD Tubing- Crystal Clear-5ft
Alphacool HF 38 Cape Cyclone 150 - Version 2
BitFenix Essentials Pro Pack - ATX 24pin, EPS 8pin, 2x PCI-E 8pin Set - Green/Black
Fittings:
Phobya G1/4" 2-way Ball Valve, Black Nickel
XSPC G1/4" Threaded T-Fitting (Chrome Finish)
1/2 barb chrome finish fittings
90 degree barb fittings
Adapter:
2x Phobya Reducing Socket G1/4 to G3/8 Outside Thread with O-Ring - Knurled - Silver Nickel Plated (These would be included with the res)
1 - 1 of 1 Posts
