Looking for recommendations for a case to replace my "Air 540". I've owned it for 2 years and am tired of looking at it. I'd also like to move back to a more conventional case since I find this one more difficult to work with then other cases I own. It's very difficult to manage the wires in the rear of the case. The size of it also makes it a tight fit when moving it in and out of the spot I keep it. This makes working on it all the more difficult and time consuming.
What I'm looking for is a black case (must be black) with a side window. The case should fit my H100i (or H110), though, I am also considering changing that out since it's also annoying to work with. The case must have the space to expand and preferably use any mobo/components I want in there. I also want one that is well built. Cost wise, I'd like to keep it under $250, but, I'm open to reasonable suggestions.
Please, suggest to me some cases since I haven't actively looked into higher end cases in a while. Not sure what's new.
Thanks.
Thanks.
