1 - 13 of 13 Posts
Im looking for a cheap sub and speakers for the bedroom (father wants his amplifier and speakers back
Don't want to spend much really as im still saving for my 5870
Been looking at this:
http://www.overclockers.co.uk/showpr...odid=SP-050-LG
Is it any good for the bedroom for music now and again and gaming, or has anyone got a better suggestion for around the same price or maybe £10 more?
If you can manage to find a set of Klipsch ProMedia GMX A-2.1 that would be close to the best sounding 2.1's you can buy. They are discontinued, which brings me to my next suggestion. I've seen them here in the states for $50 used. Being around $150 new makes them a bit out of your price range but if you actively search they are a BARGAIN for the quality and they are my longest lived computer component bar-none.
http://www.klipsch.com/na-en/product...-2-1-overview/
The x210 are very bad take a look a the x-230 a little more like 5 or 10e and they have more power... its worth it..
Originally Posted by GJF47 View Post
i can only find them in the US and shipping is a bit to much
I want to keep them quite cheap so i can get a 5870 ASAP
If you wait a little bit 5870's will be cheaper ;-)
whatever you do, don't get the Logitech LS21's like i did. every set has the same issue: the little control box does not like headphones. plug them in then unplug them and only one speaker will work. I tried cutting, stripping, and soldering the wires. did not work!
1 - 13 of 13 Posts
