This is my first loop. I've been reading about this stuff for about a week. Plan is to go with minimum maintainance. This box sits under my desk and doesn't need RGB/Aesthetics. Just need to replace the crappy h115i - should have done that years ago.
Please let me know any feedback you may have.
Questions at the bottom.
Notes:
Picture of the case is just stock, I've removed harddrive cages.
All fans are Quiet Wings 3, with exception of Kingpin AIO fans.
Every space that can host a fan will host a fan.
Triangles with fans show air flow config and number of fans.
Constraints:
I am not changing the case (Corsair 760T). I love this thing for more reasons than one.
This is a NO RGB kind of build.
All tubing will be black EK-ZMT.
GPU will be integrated next iteration.
CPU block is a joke I know. If it sucks I'll toss it.
Questions:
- Does direction of coolant flow matter? In the illustrated scenario should I reverse it for any reason?
- My AsRock Velocita Z590 does not have temperature header. How does one set up fan control based on water temp in the scenario where motherboard does not expose temp header? Is this even needed? Am I overthinking it?
