1 - 7 of 7 Posts
As the title says, im looking for a cases upside down mobo. I just found silverstone tj08-e, but it is an old product. Any suggestion? Thanks
Sent from my iPhone using Tapatalk
I know its not a "great case" by many means, but the Antec 300 is the easiest case I have ever flipped myself.
you can simply de-rivet the thing, and litterally swap the top and bottom. Drivebays will be at the bottom, but drives and res' will still mount with some drilled holes.
Do you know what rivets are? :|
I really cant think of any reversed cases aside from the V600 from lianli.
its those little thingys holding your case together!
it looks kinda like a screw
yep, if you remove them, there are so many possibilities! Aptitude required.*
1 - 7 of 7 Posts
