Originally Posted by soloz2
Never heard of that fan, the specs look decent... except it doesn't look to spin under 750RPM... making me wonder if it'll have problems starting at low speed. Also, specs don't mean too much for fans either...
The stock fan spins at about 600RPM, which is fairly quiet, but it doesn't push a lot of air and thus the cpu sit about 70-75 degrees, way too hot. So I'm looking for a quiet fan that will push a bit more air to replace it and I'll add an 80mm fan on the opposite side as intake. This fan will be soft mounted.
Well, all I can say is that my friend has a 92mm Gelid, and going full-tilt at 100% it is still almost silent, and it moves a fair amount of air. Really, in my experience, most PWM fans are pretty wimpy. Using a low speed yate loon at 100% often gets the job done much cheaper, with similar noise output.
And as far as the slipstream fans are concerned, I use them and love them. But the
only application they are any good at is exhaust. And even then, they like having nothing in way. In both my HTPC and my sig rig I am running the fastest slipstreams with the cases grilles cut out. Paired with a basic fan controller (or 7v mod) they move a good amount of air for the noise level they produce.
Hope this helps.
