1 - 19 of 19 Posts
The majority of the threads within the laptop section are threads asking about which laptop to buy. Most of those threads do not contain enough information within the original post. This thread is meant to clean up the amount of questions people have to ask to help you and deliver you a more timely response.
Please copy and paste the formatted questions below with your answers in your own thread:
What is your maximum budget?
What country are you in?
What will be the uses of this laptop?
Do you have brand loyalty or care which brands we select for you?
What screen size do you require?
What screen resolution do you require?
Are you looking to buy NEW or would refurbished/recertified/used be okay?
How long should the battery last? (Under optimal conditions, no movies/games/heavy internet)
What games would you like to play with your laptop? And on what settings?
What operating system do you need? (if any)
Is there a certain style of laptop you want? (aluminum, black, gaming, etc.)
How much hard drive space do you need?
Do you need any special hardware? (blue ray, webcam, specialty ports, etc.)
Is there anything else we need to know?
Hey; can we add this to the already stickied thread? I might change the name since apparently "read" is a scary word that people don't like.
EDIT: Never mind. That was fast to getting your own. Hopefully people read this. Nothing's worse than trying to help someone and having them disregard what you're telling them because "its not the appearance/brand I want".
Yeah I requested it be stickied, as I try my best to help people but it's difficult when they dont supply enough information to help them select a laptop; even some staff are guilty of this. I feel like those who help out shouldnt have to ask 20 questions to help out someone else, and having a system in place will allow 'us' to reply to more help threads and provide more suggestions without struggling to figure out what the user wants.
Btw I kinda felt this needed its own sticky as your thread is more of a 'I want to research about laptops myself' while this is more for those who want suggestions given to them, and to be honest no one likes reading long threads.
I hear you. No one likes to empower themselves.
Originally Posted by s-x;12987919
I quit, people ask for help and they dont even take the time to check the stickies first =.=
LOL. Hang in there bud. I know the feeling.
Don't worry, I'll probably be buying a laptop in the next couple months, and I'll be sure to use this format when I do ask.
Before you go out and buy that new laptop you promised yourself, be sure to first read this article by Kim Major. It is actually a series of 3 blog posts, that run through his considerations and conclusions before replacing his existing Thinkpad.
United States
$500 Max. Can't go any higher. No gaming, purely for school and work. No brand preference (just no Gateway). 16" screen max. USB 3.0 if possible. 4 Hours and more if possible.
Blu ray would be nice but its not by any means a deal breaker. Btw is it easy to swap out drives. My old laptop had a blu ray player.
Disk space 250GB is more than enough. 4GB ram
Originally Posted by edo101 View Post
United States
http://www.newegg.com/Product/Product.aspx?Item=N82E16834312518
http://www.newegg.com/Product/Product.aspx?Item=N82E16834230922
It's abit hard too find bluray capabilities in a sub $500 laptop. Swapping out drives is dead easy your problem would be that your copy of Windows comes as an OEM copy that's tied to specific hardware(not entirely sure about this) and different laptop DVD/BD drives have different dimensions.
OverLimit
$1350
Canada
Gaming, watching streams, and surfing.
No.
15-17 inches.
1980x1080 is a must.
Looking for new, or unless the refurbished/recertified/used are very close to new and have no damages.
Around 2-3 hours should be fine.
League of legends on high settings, maybe some cod and cs:go on medium-high settings if possible, but mostly just exclusively League of legends.
Windows 7 or 8 are both fine.
Nope.
Does not matter to me.
No.
Is there anything else we need to know? I only see laptop with LCD screens, are there any laptop out there with LED screens?
You should add a "How much wight should the laptop be" or something along that line to help narrow things down more
What is your maximum budget? $650
What country are you in? USA
What will be the uses of this laptop? School work, browsing, some light gaming
Do you have brand loyalty or care which brands we select for you? Preferably a Lenovo
What screen size do you require? As big as my budget can handle
What screen resolution do you require? Same as before
Are you looking to buy NEW or would refurbished/recertified/used be okay? New is preferable.
How long should the battery last? (Under optimal conditions, no movies/games/heavy internet) 4-6 hours is good
What games would you like to play with your laptop? And on what settings? Football Manager, mark of the ninja. All the light games
What operating system do you need? (if any) Nada
Is there a certain style of laptop you want? (aluminum, black, gaming, etc.) As plain as possible.
How much hard drive space do you need? 500GB+ of HDD. Would like 7200RPM, but can do with 5400
Do you need any special hardware? (blue ray, webcam, specialty ports, etc.) Nope
Is there anything else we need to know? Nope
Thanks friends
What is your maximum budget? A good budget would be 1200$ but I would need to check with my cousin who I am shopping for in her stead.
What country are you in? - United States
What will be the uses of this laptop? - Heavy Multimedia use with emphasis on superb sound quality. Also with Photoshop and video editing for business purposes.
Do you have brand loyalty or care which brands we select for you? Any brand as long as it is good and won't break down in five years plus.
What screen size do you require? Big as can be
What screen resolution do you require? 1980X1080
Are you looking to buy NEW or would refurbished/recertified/used be okay? Laptop will be new!
How long should the battery last? (Under optimal conditions, no movies/games/heavy internet) 6 hours +
What games would you like to play with your laptop? And on what settings? Laptop will not be used for heavy gaming although there will be simple little games to pass the time, nothing hardcore.
What operating system do you need? (if any) Don't care
Is there a certain style of laptop you want? (aluminum, black, gaming, etc.) No style preference
How much hard drive space do you need? As much as I can get
Do you need any special hardware? (blue ray, webcam, specialty ports, etc.) Good sound card for the sound quality and be able to burn cd's.
Is there anything else we need to know? Budget may change but will get back to you guys. I appreciate the help I will get as I do not know much about laptops. Thank you!
1600€
Germany
Office, internet, photoshop and (but not neccesary) games
definitly not acer or similiar crappy qualitay (had 2 acers before)
not larger than 15"
1080p is enough
everything that still has 2 years+ guarantee will be fine
8 hours+
gaming is absolutly not important. if i play, then heroes of might and magic 6 on medium or sonic racing. but actually, i don't care if I can play video games or not.
i'm goint to install windows 7 myself (or maybe windows 8 if it'll have a touchscreen)
ultrabook, touchscreen preferred
ssd with 256gb+ and a hdd with at least 500gb
no
I am currently thinking about dell xps 13 i7 or the lenovo carbon x1
buuild quality is very important for me
Laptop Enthusiast
I think people need to read the first post again....
1 - 19 of 19 Posts
