Status
Not open for further replies.
1 - 20 of 510 Posts
Are you going to buy a mouse/mousepad? Help us help you and please answer at least the first two questions below. If you have no clue about the questions, please take some time to read the explanations.
Questions
Please copy and paste the formatted questions below with your answers (at least the first two questions!) in your own thread (or in The Mouse Suggestion Thread):
1. What's your grip style?
2. What's your sensitivity?
3. What's your maximum budget?
4. Do you want additional buttons?
5. What games do you play?
6. Do you mind about prediction?
7. Other relevant information:
Input anything else you want.
some examples: LOD, ambidextrous shape, weight, wireless, non-braided cord, glossy finish, button activation force, driverless, onboard memory, etc
If you're looking for a mousepd too, please try to answer the following questions:
7. Hard or cloth?
8. Rough or smooth?
9. Which size approximately?
10. What's your maximum budget?
Explanations
Grip
Grip style or grip type is the manner with which you hold your mouse. There are three main styles:
  • Claw grip
  • Fingertip grip
  • Palm grip
The grip type allows to choose the shape and weight of the mouse.
Example: fingertip grippers will most likely want small and lightweight mouses.
More info: Razer.
Sensitivity
Sensitivity represents how fast the mouse cursor moves in relation to the mouse physical movement. For FPS games, sensitivity is commonly defined by distance/360°. Or, more generally, it's defined by low, mid or high (please refer to the link below if you're not sure).
Example: 50cm/360° (to make a full 360° turn, it's needed to move the mouse by 50cm). That's an example of a low sensitivity.
The sensitivity allows to choose the dpi of the mouse and, most importantly, it defines the top speed needed.
Example: low sensitivity players very often hit high speeds; thus, they need a mouse that can support those high speeds without any kind of acceleration or malfunction.
More info: ESR.
Prediction
Prediction (aka Angle Snapping, Drift Control, Correction) helps you to draw straight lines: the mouse tracking corrects (removes) the minor deviations from your line, making it as straight as possible, up to certain threshold, which varies from mouse to mouse (some mouse has more prediction than others). Ideally, a mouse should have the option to turn off the prediction, but there are plenty of mice with inherent prediction that can't be turned off.
Ty for this topic F u r u y á ! I think it will help some people who need to buy some mice.
The only thing i think you forgot is that people need to say if they want an optical/laser sensor or don't care.
needs a "commonly-recommended mice and mousepads" section imo, just so readers have a general idea on what to look for.
Yes. This. I love the XTrac Pads Ripper XXL.
-Wrong thread, please delete-
Claw grip
2000dpi
£75
Nah
DiRT 3, Minecraft
No Razer.
Claw grip
2000dpi
£75
Nah
DiRT 3, Minecraft
No Razer.
  • Cooler Master CM Storm Spawn<--the mouse i recommend everybody for clawgripping. its cheap, awesome sensor and perfect for claw grip
  • Logitech G9x<--positive acceleration. It depends on wether u like it or not, a lot of pros use it
  • (ZOWIE MiCO)<--only 1600dpi
Fingertip grip
Mid
120 $
No more of 5
CS 1.6, Crysis, CoD, Assasin Creed, Grand Theft Auto, Portal
No Prediction
I saw the Zowie Ec2 EvO, and like me, but is good enough? Or another mouse is better?
Fingertip grip
Mid
120 $
No more of 5
No Prediction
Id have to recommend the Logitech G9x. I use a finger tip grip and I honestly dont wanna try a new mouse anytime soon. Ive had this thing for nearly 3 years.
I'm actually looking for a mouse, so I'll take a stab at it.
1. What's your grip style? Fingertip in FPS, probably palm in slower games.
2. What's your sensitivity? I want 1500-1800 minimum with an adjustment up to 3500 at least
3. What's your maximum budget? $75
4. Do you want additional buttons? left, right, two thumbs, and a scroll wheel is all I really need
5. What games do you play? Skyrim, various BF games, some other shooters
6. Do you mind about prediction? rather not have it
Not heavy, drivers are fine as long as they're simple.
http://www.newegg.com/Product/Product.aspx?Item=N82E16826104261
same thing I said to the guy above you.
I tried one at a store, but it's just a little too small. I have fairly large hands.
From what I see, my requirement in a mouse are really similar to yours. I ended up buying a Deathadder Black Edition and it is perfect for me. Note that I have really large hands, and that I am using it driverless.
Palm
1000 maybe?
No Budget
Sure why not. More buttons the more I can move commands to the right hand.
All and any of them. Example: Battlefield 3 and Guild Wars 2.. etc... etc..
If the mouse can go where I want it to go before my brain can signal my hand to do it and improve my gameplay.. sure give me more mouse prediction?
Wireless... Cords annoy the **** out of me, and tech should be good enough today where the delay between cord and wireless is non-existant??
I hate my wireless mouse/keyboard randomly disconnects......
Also Ill take anything that improves gameplay.
7. Hard or cloth?
The one thats better for gaming? I usually use the normal mousepad plastic part?? lol
8. Rough or smooth?
Maybe just slightly larger then Normal... Otherwise Normal?
None
lol'd
Prediction actually straighten your mouse movement to make them look more like a straight line.
There arent many wireless mouses around. You should take a look at the logitech g700, the cyborg R.A.T. 9 , the logitech performance MX or the razer mamba. I would personally chose the g700.
Fingertip Grip
Medium
$60
Not needed
Battlefield 3
No
Wired mouse ftw!
Mousepad
7. Hard or cloth?
Cloth
8. Rough or smooth?
Smooth , I think...
Medium to Large with a Wristpad if possible!
$30
Thanks!!
Palm and claw grips
800~1800
60$
Two on the side (backward \ forward) can be good.
FPS - cs1.6 etc..
No prediction for me.
No accel, no prediction, no glossy sides\top.
I think about the G400. What do you think? You reccomend this mouse for me?
7. Hard or cloth?
Cloth
8. Rough or smooth?
Smoth
320 X 270
30$
1 - 20 of 510 Posts
Status
