Hello OCN community,
I'm wondering if I can get some opinions on a certain CPU I'm looking to buy. A seller has presented me with a Delidded 3770k with the following specs:
OC stable 4.5GHz
1.275 ~ 1.3V *
30 degrees idle, 65 degrees stress testing
*he forgot exact voltage as he reduced it to 4.0Ghz shortly after finding his max acceptable OC with the above specs.
Would you guys say this is fairly decent? Or should I look into another processor? I'll be replacing my 2500k cpu with it and upgrading my video card to a GTX 970. Looking to upgrade on a small budget so I can't get a new 4790k + systemboard.
I've updated my systemboard to Asus BIOS 3501, so I believe I should be able to drop the cpu in and run with it without any problems. Please correct me if I'm wrong.
Thank you
OC stable 4.5GHz
1.275 ~ 1.3V *
Thank you
