I wasn't sure whether to put this into the PSU or computer cases section.
EDIT: guess I should have put it into the case mods section
I'm looking to mod my Antec 902 so that the PSU fan draws air from under the case. I googled and I couldn't find much of an answer to how much clearance I should have. The case sits on my desk so carpet isn't an issue here.
I measured the space underneath the case, there is a bit more than 3/8 inch of clearance, and the 902 has rubber PSU mounts that add another ~1/8 inch. Will this be enough for the PSU to draw air, or will I have to elevate/add feet?
