1 - 3 of 3 Posts
Hello,
I'm looking for my 15 retina replacement. I've used all search engines and spent like 2 hours searching but I can't find a viable laptop. It will be used mostly for internet, movies (on screen/HDMI), watching streams and maybe some light games.
I'm looking for something like:
- 13 - 14 screen with preferably full hd, but if it's cheap laptop I won't mind the 1366x
- SSD (either it comes with it or I can swap it out after, one disc is enough)
- HDMI
- Battery life (should last around 5-7 hours)
- Would like it thin and light (I'm ok with my retina thinness, maybe little more would be ok)
- $300-700 (I set the limit at 700 since if I go higher I might aswell get Macbook air but it lacks the HDMI so I'm not sure)
- Decent design wouldn't hurt
- I would like decent touchpad placed in the middle (no idea who started moving touchpads to the left)
I would leave chromebooks out, I need windows for school and other stuff but the laptops would be perfect for me.
Try searching it on this website if you could, thanks: http://www.heureka.cz/
Yes, that looks like something I could get, but it's kinda too expensive and not for sale anymore, I can just add a little and get air. I'm probably gonna get the second hand air anyway, would be best buy for around $800-1000 used.
1 - 3 of 3 Posts
