Looking to upgrade my GPU
1077 Views 26 Replies 8 Participants Last post by  Malaziel
I would like to hear some advice from the experts.
I have a P4 2.4GHz 478socket, 512MB RAM (of which I don't know the specs) and an old NVidia GPU GForce with 64MB RAM (@200MHz IIRC).
I am looking to replace my GPU and I would like to stay with NVidia because it has been proved robust. I am not a super-gamer neither I use my PC for super dupper entertainment. I am looking for something cheap that will offer a great improvement to my current setup. It would be nice to enjoy some games without the quality compromises I currently have and watch a movie without freezing.
Any suggestions are welcome.
Edit: The Mobo is an ASUS P4P800S-X
21 - 27 of 27 Posts
if you want to save some $ and still have pixel shader 3.0 and not pay 100E for the card, then you can just get a plain vanilla 6600LE
edit: my bad its pci-x, for agp i'd go with either a x700 agp or a 6600LE agp.
or if you don't want to pass the $100 line... there is something you might like
http://www.newegg.com/Product/Produc...82E16814153012
http://www.newegg.com/Product/Produc...82E16814131227
http://www.newegg.com/Product/Produc...82E16814133151
http://www.newegg.com/Product/Produc...82E16814102510
http://www.newegg.com/Product/Produc...2E16814121205R
I would recommend this
http://www.newegg.com/Product/Produc...2E16814131307R
PixelPipelines 8
OpenGL 2.0
Thos are all AGP... as you have a 478 p4 i tough you'd be on agp...
I have a 9600XT, and I can run every game in the market...
not in very high details... but in medium
Discussion Starter · #23 ·
Thanks a lot guys that is very helpful.
For those of you with the 6600GT how far it can be overclocked?
I mean is the limit even higher or is it from stock as far as it goes?
What resolutions should I be able to run in games with that and my current setup?
Discussion Starter · #25 ·
Sorry to bother you guys about this again but I have been a bit short on cash lately and I am now looking again into this. I was looking at this card http://www.microdirect.co.uk/Product...84&GroupID=331 compared to the 6600gt which most of you suggested . It seems that the 6600GF has much more memory and it too supports shader model 3.
Which is best?
The 6600gt is quite a bit more powerful than that. The 6600gt that was suggested to you earlier is actually a PCI-Express which is not compatible with your motherboard so I shall suggest this
http://www.microdirect.co.uk/Product...69&GroupID=331
Which is compatible.
That is a good card for the money right now and from the description that you provided it sounds like just the card for you. Very good for budget gaming as it will play even the newest games at medium settings and no card can really compete with that for the price.
21 - 27 of 27 Posts
