1 - 4 of 4 Posts
Hi<br />
I just bought a linksys wireless router and I always loose the connection.First its at 54 mbps the it stats decreasing and I loose my internet connection. I think its because I have a wireless phone (5.8ghz) in my room.Is it the problem?Is yes how can I resolve it?If no,what can be the problem?<br />
<br />
Thanks alot
9 Cans of Ravioli
A 5.8Ghz phone wouldn't interfere. A 2.4Ghz would, though.
a common problem is that people using a USB internet modem switch it to the ethernet cable without having installed the ethernet drivers on a host computer. I find all problems resolved by having a host computer (the one that should have the drivers) that computer should be connected to the router via ethernet and the other nodes can use wireless without issues
1 - 4 of 4 Posts
