1 - 14 of 14 Posts
So...my dad lost his restore CD for the family eMachines.
I got the windows xp cd-key with some jelly bean key extractor thing...
so if I pop in my own windows xp cd with SP2 and put in his cd key will it work on that computer? cause I wanna reformat it, but I can't find the cd.
I just wanna make sure it'll work before I do it, cause otherwise it'll be a useless computer. Will it check for stuipd emachines software? I just want it to work right again, and a format is the only way lol.
Cookies for those who help.
I highly doubt it because I don't think the pre-built computers have specially designed HD or anything. I know that you need to use designated RAM for the mobo and all that, but no HD issues.
Because I got a Windows XP CD from a friend when I kind of built the machine, and I used the HD from Sony VAIO. Didin't give any problems.
So you're saying it would work? Just install on HIS computer with MY cd....then put in the original CD-Key from his install? and that should work?
Yeah. It should. It's like installing games. You can use the same CD over and over again as long as you have different CD key.
Discussion Starter #5
Thanks man. Cookie for you!
Discussion Starter #7
Originally Posted by cdub998
Wooaahh. hold on one sec. Does he have pro or home on his pc?
We both have Home
Discussion Starter #9
Cool I'd hate to see you not be able to use his key.
So there's no issues?
Is your copy OEM or retail? I'm pretty sure that an OEM key from an e-machine will not work with a retail version of xp.
Discussion Starter #12
I bought my XP cd "OEM" from ncix. It just came with a little book about Windows or whatever and how to install, and was in a plastic sleeve. No box or nothing.
What's the difference between an OEM and a retail Disc? don't they just not give you a box?
Yup,thats about the only diff, and the keys are not interchangeable from what the techs at work say.
Discussion Starter #14
So if mine are both home then it'll work fine...right? Just wanna make sure...otherwise the computer will basically become unuseable...
1 - 14 of 14 Posts
