Lots of voltage change during prime 95
300 Views 1 Reply 2 Participants Last post by  supaspoon
Is this normal, my voltage changes a lot. The reason i am wondering is because me and my friend both have the same problem. With any change in our bios to voltages, our computers wont boot properly.
1 - 2 of 2 Posts
It's normal. If you've left off llc it should go down as your cpu loads. If you have llc on, it will move up instead, but in a smaller amount of fluctuation.
Nothing to worry about.
1 - 2 of 2 Posts
