Ok...so I need some suggestions on my first serious water cooling setup. I am in the process of meticulously planning everything and this is what I have come up with:
-XSPC Dual 5.25" Bay - DDC Dual Pump / Dual Split Reservoirs
-2 x Switftech MCP350
-Black Ice GT Stealth 280 Radiator (4x140mm fans P=>P)
-EK Supreme HF Full Nickel CPU Block
-EK-FB ASUS Crosshair 4 - Acetal + Nickel MB Block
**Suggestions are welcome on better options for my sig rig; noting that the 650D will only fit the RS rads, not the RX or XTs**
1) I planned on this setup, knowing that once I upgrade my video card I will be wanting to add a GPU block as well (In the mean-time I would run one loop for the CPU, and one for the MB block). Would it be necessary to have 2 pumps (not necessarily 2 separate loops) to run the CPU, MB, and a single GPU loop? Could I get away with the Res/Pump that comes with the RASA 750 RS240 kit to run the three blocks in a loop?
2) Also, when I add the GPU block I will need to add another radiator to the mix at that point... I am thinking about one of the 200mm extreme rads that I saw in a 650D mod here on OCN... would the 280 and a 200 be sufficient for the 3 blocks and a possible future Crossfire upgrade?
3) Would I be better off running a single big loop with multiple pumps, or two separate loops with separate pumps and rads? If I were to run separate loops, would it be best to run the CPU on its own loop, and then put the MB and GPUs on the other... or would another combination be best?
4) What type of tubing, compression fitting/barbs, and "coolant" do you recommend (black or red theme pls)?
I welcome any and all cometary... I will probably not be ordering any of this for at least a month, and in the mean time I want to optimize my setup based on suggestions I get from the community here. Rep will be given to anyone who directly answers any of my questions. Thanks
