1 - 8 of 8 Posts
X6800 at 3.6ghz with x1900 CFE at 725/774 and x1900xtx slave at 729/783 I get around 59,500 in 3dmark01 and around 18,800 in 3dmark05. I haven't tried 03 and 06 yet. But shouldn't I be getting a little bit better scores? I have seen people with much higher scores but also lower clock speeds on video cards and CPU.
Nope, those are very very good scores. Chozart gets about 10k in 06 so you should be fine...it even seems a little high but given the X6800 its believable.
Discussion Starter #4
Are you sure? Chozart got 20,586 in 3dmark05 with E6600 at 3.5 and x1900 at 677/778(1556), his cpu and gpu speeds are both lower than mine.
Driver settings.. check if everything in CCC is set to performance.
Low?That's no low,any way with the C2D evryone is getting close to that and in 2001 SE, all the ppl pass easy the 50,000 mark.Im still @ 35,000 in 3d 2001 SE.I think the 2001 SE have something with the C2D,none of the AMD can't touch 50,000 mark.How is tha't?Any patch?Different set up?I don't get what's happening?
Im at 3598 lol. But im not a gamer so its not too much of gamer.<br />
If I do a mild overclock I get 3956 but that gain is probably to small to be worth it.
1 - 8 of 8 Posts
