1 - 13 of 13 Posts
I have a Dell XPS 400 using an Intel Pentium D 930 @ 2993 Mhz and after testing it on 3DMark05 a short while back, I had a low CPU score of 4909. Shouldn't the Presler core line all receive over 5500? And there is no junk on my Dell, since I have reformatted and downloaded all the lastest drivers from Dell and nVidia. Could it be a motherboard driver problem because the latest Intel Chipset driver from Dell was from January of 2005?
Here are my specs:
2 X 1024 MB DDR2 533 Mhz RAM in DC
375 Watter Power Supply (Can't be powersupply fault because XPS 400 supports the power hungry ATI X1900 XTX)
nVidia 6800 Vanilla 256 MB @ 430/828
Intel 945G Motherboard (Speedstep disabled)
2 X 160 GB SATA II HDs in RAID 0
Sorry to say but that a dell thing.
Company limit something in which to less performance.
No, I don't think that's the case though. I've compared several computers with my 3DMark05 CPU score with computers that have the same specs as mine and are all manufactured from Dell. All of their CPU scores were above mine which were in the range of the 5400+.
Administrator
You will get a much better score if you stop any needless processes or go into MSCONFIG and stop needless programs from starting up. Also disable and CPU using tasks such as your Firewalls or Anti-viruses and run it again. To improve windows check my Windows FAQS in my Sig.
Disabling certain services can help too.
Discussion Starter #7
Yep, I only have 20 processes when I startup using only about 140 MB of RAM.
Btw, I just downloaded the Microsoft Dual Core patch and it bumped my CPU score to 5447! So my highest 3DMark05 score now is 5116 but isn't 5447 still a tiny bit low? The Pentium D 820 gets about 5447 while the 940 gets 5820 from benchmarks I've seen.
Here's the link to the scores. http://service.futuremark.com/orb/pr...jectId=2319291
Discussion Starter #9
There were absolutely no firewalls on and I even disabled the internet. Virus and spyware free also. Would an Intel Chipset update work for a Dell Motherboard thats 945G?
Administrator
Yes indeed it would. Something you definately need to do.
Discussion Starter #11
Ok, thanks but on the Intel website, when I look at the chipset drivers they are only inf updates and not a specific driver update. Am I supposed to download something from desktop boards? And if I do a BIOs update it'll screw up my computer since it uses a custom Dell BIOs.
1 - 13 of 13 Posts
