Ok, thanks. I will do that after I finish my Prime95 Torture test.Originally Posted by stubass
665 with DDR (Double Data Rate) = 665 x 2 = 1330MHz as CPU-Z will report the actualu single lane freq ( i think thats what its called) which must be doubled to get your actual freq.
ok so you want to make use of your 1600 so CPU-Z should report it as 800.. What you can do is is set the XMP to profile 1 in bios or if that doesnt work you might have to bump the RAM freq multipler and a .05 or .1V bump..
chossing an XMP profile should work so try it first
oh onething your RAM running at 1330MHz with timmings of 9-9-9-24 and a cmd rate of 1T would be super awsome fast an if you can run Maxxmem^2 to bench it and show us the result. im betting it will be awsome results.
is that sapposed to be special? i have 1T on too.Originally Posted by stubass
oh onething your RAM running at 1330MHz with timmings of 9-9-9-24 and a cmd rate of 1T would be super awsome fast an if you can run Maxxmem^2 to bench it and show us the result. im betting it will be awsome results.![]()
then once you get it to 1600MHz run the test again and compare please if you have the time. cheers![]()
oh yes at 1600Mhz his RAM will be at 2T but i would like to see how his RAM performs
Wowowowowow. to think i was going to buy a motherboard so i could just clock my ram upto 1600mhz.Originally Posted by stubass
oh yes at 1600Mhz his RAM will be at 2T but i would like to see how his RAM performs![]()
Some tests i done with my RAM (more to come) i found 12GB at 1333 9-9-9-24 1T was close to the performance of 16GB 1600 8-8-8-24 2T.
12GB at 1333 9-9-9-24 1T was a vast improvment over 12GB at 1333 9-9-9-24 2T.
Note: 16GB is full dual channel mode
12GB tests is flex mode with 8GB in dual channel with 4GB in single channel even though MaxMEM^2 reports it as dual channel
RAM used G.Skill RipjawsX DDR3 1600 CL8
the second two test really show the difference between cmd rates of 1T and 2T
The real world difference between 1333 @ cmd rate of 1T compared to 1600 @cmd rate of 2T doesnt seem worth it tho if i can get my RAM to perform at 1600 @ 1T, i am expecting a very noticable jump in performance in in MaxxMEM bench results but will I notice it in normal PC operations!!Wowowowowow. to think i was going to buy a motherboard so i could just clock my ram upto 1600mhz.![]()
tell me when you get 1600mhz in 1TOriginally Posted by stubass
The real world difference between 1333 @ cmd rate of 1T compared to 1600 @cmd rate of 2T doesnt seem worth it tho if i can get my RAM to perform at 1600 @ 1T, i am expecting a very noticable jump in performance in in MaxxMEM bench results but will I notice it in normal PC operations!!![]()
see below lol
well 16GB RAM with a CMD Rate of 1T over 2T didnt make a any difference, therefore my assumpotion was wrong lolOriginally Posted by stubass
