1 - 14 of 14 Posts
I've been trying to overclock my 7600GT and for some reason, with both coolbits and rivatuner, I'm not able to achieve speeds close to what other people/sites report. This is my first time overclocking anything and I'm not quite sure what's wrong.<br />
<br />
My Memory clock doesn't even go above about 750-760 Mhz before it says that the internal test failed.<br />
<br />
My driver version is 8.4.2.1 and my bios version is 5.73.22.15.01.<br />
I'm running an AMD Athlon 3800+ with 200gb hd and 1gb of ram.<br />
<br />
Any help is appreciated.
same card, and I may get boo'd for this, but have you tried systool?
<div>Originally Posted by <strong>jcbzhnsr1</strong></div>
<div style="font-style:italic;">same card, and I may get boo'd for this, but have you tried systool?</div>
</td>
</tr></table></div>
Your avatar makes me want to cry <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown"><br><br>
ON TOPIC:<br><br>
What are your temps?
You should download the 9.1.4.7 drivers because thoose ones i had trouble overclocking with to. <a href="http://www.nvidia.com/object/winxp_2k_91.47.html" target="_blank">http://www.nvidia.com/object/winxp_2k_91.47.html</a>
Discussion Starter #5
Yeah, I tried with those drivers also, but I still had no success in overclocking above 750 Mhz.<br><br>
My temp is only 50 C
Discussion Starter #6
</td>
</tr></table></div>
what would I need to do with that?
Super Noob
well i guess you got an unlucky card cause i get around 860 without v-mod
Yea, both of mine are running at 610/820. Must be a bum card.
<div>Originally Posted by <strong>bdattilo</strong></div>
<div style="font-style:italic;">Yea, both of mine are running at 610/820. Must be a bum card.</div>
</td>
</tr></table></div>
What makes a card "Bum"? I'm not being "smart", I really would like to know. Isn't there anything that can be done? Is there a "CMOS-like" reset, or a utility or something that can "Flush" the settigs? Or is is purely physical?<br><br>
I guess I got lucky too. When I was using my 7600GT as my primary I ran it at 626/850 w/o a volt-mod.
Discussion Starter #11
More developments:<br />
I can overclock my core speed to 645! My 3D benchmark score goes from 3000 to 3200.<br />
However, my memory speed still gives me the <br />
"The driver failed to pass internal test with the clock frequencies you are about to set. Please decrease clock frequencies and try again" when I try to increase the memory clock speed over 759 MHz.<br />
<br />
Any other help would be appreciated!
stock cooling I take it?
1 - 14 of 14 Posts
