Low Scores for X1950Pro
526 Views 11 Replies 7 Participants Last post by  PhotoSnap
3DMark01SE: 30898
3DMark03: 16078
3DMark05: 6808
3DMark06: 4599
Why are these so low, yet my specs are like, really good.
1 - 12 of 12 Posts
Disable anything running in the background that you do not need. See if that helps your scores.
Those scores aren't all that low for that card, but try going into the drivers and setting everything to performance.
Like Dennisjr13 said.
-run/'prefetch'/delete all files/restart comp (minor improvement)
I get 5069 on 3dmark06 at stock everything. What you have is about right for your card.
As for 3dmark05 -> 10281 at stock everything. I would've guessed yours to be at least 8000.
6843 on 3dmark05, I just put everything on performance and I still get nothing good in it.
I am running dual os, so I installed Vista to test these benchmarks, 3dmark05 is 9888 =)
I easily get over 10k in 05' with a single card, 15k+ when using 2 cards. Is this on a fresh install of Windows?
are you saying you actually scored higher on Vista???
Somehow I did, when I run it in xp, I get way lower, and yes these are both fresh installs.
props to ATi for their Vista drivers then. good score, mang
Thanks, like 3dmark05 runs way better on vista, so does 03. but 3dmark01 has issues, and 3dmark06 won't open for me on vista.
I'm still exploring =)
1 - 12 of 12 Posts
