1 - 9 of 9 Posts
Hi!<br />
<br />
I got a ampifire pluged in my computer , and a 2.1 system , it sound nice , or should i say , sounded nice ? becase my amplifire has a problem i think <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick out tounge caps" class="inlineimg" /> i got it on the highest volume level , and is sounds like someone are whispering the songs i play ? i checked so the sound is at full in all the properties that i can found , please help me ? whats wrong i what that high i was before
Is it powered my the 3.5mm plug into ur PC only? if it is thats ur reason... if not, reinstall ur drivers.
Make sure other programs aren't forcing to to be so low. E.G. Check that MSN's voice/sound features. I've had problems with that before, if that doesn't work just try restarting your PC.
Discussion Starter #4
restarting doesnt work , and yes its inplugged with 3.5 only to my computer , why ?
I have an amp on my comp with 3.5mm and its extremely loud, what are all the setting you have set in the audio drivers<br><br>
Is it an amp and a 2.1 system where the they plug into the amp or are they seperate systems
do you use winamp ?<br><br>
i find if i mute the sound on winamp it mutes all sound but if i check in the volume controls it still says its on full.<br><br>
might wana check that
Discussion Starter #7
mootin , sry i didnt understand what you said , And i got a sound sharer in my soundcard , that makes so i can have bot the amp and the 2.1 system plugged in at the same time !
Splitting the jack halves the output <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
Discussion Starter #9
yes i know that , but the sound have been louder before than what it is now !
1 - 9 of 9 Posts
