So, I did a thing...
I've heard a-lot of people saying that you cannot put a PC in a freezer, and have seen quite a few try and fail.
So, I got my torches out and went shopping for materials to build an insulated box. Somewhere around the 300$ mark i saw a little chest freezer that was just about the size I wanted for 115$. Sold.
Well, to anyone interested, here's a PC in a freezer. Albeit heavily modified freezer*
Gutted a freezer. Cut a hole in the top. Installed and sealed a viewport. Put a much bigger condenser on it. Put a much bigger evaporator in it. Put a bigger compressor in it (still quite a bit smaller than the ones I see people use from window AC's, about half the size in comparison).
Used cheap fans for the coils as I wasn't sure if they would have the static support to pull through the coils.
Turns out they are great. I will be buying some magnetic high static fans to replace these.
Tips and Tricks:
Fixed metering device is a no go and will only get you to one temp and will be inefficient to maintain.
Internally equalized TXV will be problematic at low temps (below freezing).
Use externally equalized TXV as this will balance the temps under various different loads. Get an adjustable one for the best refrigerant control.
For ultra-low temps, use a custom sub-cooler on your liquid line. Mine is ten 7/8" loops of 3/8" copper through 1-3/8" canister.
Use a suction line accumulator to protect the compressor from liquid refrigerant under various loads.
When balancing the charge in the system, bottles of hot water simulate a heat load very well.
PSU and HDD/SSD's go outside the unit.
Insulating foam and cork tape to seal penetrations.
Vacuum port to remove moisture.
Use Larger than 1/4" acrylic as the 1/4" will bend and buckle under 15" vacuum.
Use a solenoid in conjunction with a high pressure / low pressure cut out control. This will prevent warm refrigerant from migrating to the evaporator during off cycles and help the box retain low temps longer and fewer runs per hour.
**If you run the system with no cold storage, it will cycle constantly and fail to keep up under heavy load.
Currently 3 gallons of water in the bottom of the freezer. This is where the latent heat gets absorbed during normal operations and prevents the system from cycling constantly.
Testing with cold storage at -10c yesterday, the compressor would cycle 2 times an hour rather than the 6 I had allowed it. During CPU benchmarks (nzxt z73 surprised it's still pumping haha) the CPU will still get up into the 40's at 4.8ghz and into the low 60's at 5.4ghz. The GPU is still air cooled (custom low temp loop coming soon. sponsors?) and will get up to 68after repeated benchmarks and actually takes a bit to cool down where as the CPU returns to negative temps within seconds. With the CPU radiator in direct exchange with the evaporator (below the test bench) it takes a very long time to heat soak it. I am currently relying on a mobo probe and GPU probe that can read negative temps, so after the CPU or RAM are below 0c, its all a guess.
Pulling my cold storage down to -15c today my onboard SSD stopped reporting somewhere around -12c (I forgot it was still in there. It still works in the laptop, so only problematic at low temp.)
So there is is guys, a freezer PC. It is, the most expensive and impractical PC case I have ever built, but I dig it haha.
Charging and balancing the system to respond correctly under different loads had been, tedious, so if you're going to build one, pack patience.
Tons of pics and additional info for anyone interested. Hope at least a few of you get a kick out it, i got a kick out of building it.
