I posted this picture in another thread with a separate intention, but upon posting it, I noticed something with the voltages. My voltage for some of my rails seems low, namely the +3.3V rail but also the +5V rail.
This isn't the first time it's happened.
A good while back, I had a crash and Blue Screen while playing The Sims 3, and at another forum, we figured it was my CPU, which I thought was 100% boringly stable and hadn't had any issues at the voltage it was running at for over a year, wasn't stable (Intel Burn Test exposed it). Prior to discovering that, someone mentioned in one of my photos that my rails looked a bit low. Here are those photos from then (keep in mind these were months ago whereas the one above was last night). Someone looked over my log and said "everything points to the CPU", and someone else said not to worry (not to trust software readings or some sort if it was stable) about the PSU so I didn't.
Here are the photos from then.
Is this normal/okay? Are they too low? Are they too inconsistent? Am I risking anything? After I swapped out my GeForce 8800GT for my GeForce GTX 560 Ti, the +3.3V rail went up a little. Why? Why would the GPU influence the +3.3V rail? I soon after cleaned out my PC, including the PSU, and it went up a little more (~3.2V), but now it's apparently dropping again, or it never up to begin with and is just that inconsistent. The issue seems to effect the +3.3V rail the most, but the +5V rail seems to be doing it to a degree too.
The PSU still has warranty on it. Is this okay? I don't want to ignore it since there's no issues that I notice if there's a chance it's "bad for the hardware".
Also, here's the test paper thing I got with it (if it even means anything, I'm not sure). I noticed one of the results says "fail" on line 80.
