1 - 11 of 11 Posts
Old to Overclock.net
<font face="Tahoma"><font size="4">I've been noticing my temps going up the last few months. I knew this was because it was high time for me to change my coolant. The coolant had bits of stuff floating around in it. I had been using T.T. coolant and I think it's no more than auto antifreeze. This time I used Water Wetter with distilled water. I first flushed my system very well using bleach and watter. I used about a half ounce of bleach to 12 ounces of water to flush my system. I repeated this till it was all clear, three times for me. I also ran my pump for about 10 min. each time too. My temps are now about 7 to 10 deg. lower than before.</font></font>
try to not use extremely large font next time <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />...just a suggestion. <img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
<tr>
<div>
Originally Posted by <strong>phantomgrave</strong>
<a href="showthread.php?s=f0ff622456a527c34b14aeab359ee59d&p=1395424#post1395424" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">try to not use extremely large font next time <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />...just a suggestion. <img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /></div>
</td>
</tr>
</table>
</div><font face="Arial Black"><font size="7">WHAT ?</font></font>
What is the point of this thread anyways? Just to let people know you got lower temps cause you changed your coolant? <img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" />
<tr>
<div>
Originally Posted by <strong>dmhnc</strong>
<a href="showthread.php?s=f0ff622456a527c34b14aeab359ee59d&p=1395486#post1395486" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic"><font face="Arial Black"><font size="7">WHAT ?</font></font></div>
</td>
</tr>
</table>
</div>Seriously, just use the normal font. You'll get the same response as you would without the big font. Trust me.
not that im an expert but i think your temperatures went down because you changed your THERMALTAKE coolant, from what i heard, thermaltake water cooling products arent as good as others so... there might have never been a problem with what was in the coolant rather than it being the quality of the coolant.
<tr>
<div>
</div>
</td>
</tr>
</table>
</div>Dood, why are you shouting, we're not deaf...<img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
<tr>
<div>
<a href="showthread.php?s=f0ff622456a527c34b14aeab359ee59d&p=1395400#post1395400" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic"><font face="Tahoma"><font size="4">I've been noticing my temps going up the last few months. I knew this was because it was high time for me to change my coolant. The coolant had bits of stuff floating around in it. I had been using T.T. coolant and I think it's no more than auto antifreeze. This time I used Water Wetter with distilled water. I first flushed my system very well using bleach and watter. I used about a half ounce of bleach to 12 ounces of water to flush my system. I repeated this till it was all clear, three times for me. I also ran my pump for about 10 min. each time too. My temps are now about 7 to 10 deg. lower than before.</font></font></div>
</td>
</tr>
</table>
</div>TT coolant sucks ive had stuff floating in it too make sure u add something to stop the forming of algae i suggest a 1:20 ratio of car antifreez works great 1ml:20:ml of water a easyway to do this is take a 50ml cup and fill it once with antifreez and then just refill it 20tmes with water mix it and there u go algae free coolant
<tr>
<div>
</div>
</td>
</tr>
</table>
</div> Are you sure you dont have Delta fan?...<img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" />....<img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
Discussion Starter #10
<tr>
<div>
Originally Posted by <strong>Syrillian</strong>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1395546#post1395546" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Dood, why are you shouting, we're not deaf...<img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /></div>
</td>
</tr>
</table>
</div> <font face="Courier New"><font size="1">oh,sorry............</font></font>
Behave man
1 - 11 of 11 Posts
