Ok, so I originally posted on the wrong forum (overclockers.com!!!, lol)
So I'm planning an i5-2500 or BD m-ITX build for the summer. The goal is to have a small, space-saving box, but I am still open to m-ATX if it's much, much smarter.
I plan on using this case, but I am 100% open to new ideas, especially small, good m-ATX cases:
http://www.canadacomputers.com/produ...item_id=035189
The goal is to put an i5-2500(or k), an aftermarket heatsink and fan, one (or two
) GTX460 or 6850, 8GB ram, and one (or two) hard drives. Will this be fine with the stock 450W PSU, if I only go for one GPU?
How much more do you think I'm going to pay for a m-ITX build over a m-ATX build? I'll forgo some space-saving if it means a hundred or two hundred dollars saved in cases and mobos.
What about the heat? My region gets really hot sometimes, 30+ degrees indoors in the summer, and I worry about the components being in such a small area with not the best ventilation. Is there anything I can do? I'll have 3-year warranties on most pieces, but I'd rather play it safe.
Thanks everyone. I'm totally new to m-ITX's and need help from the pros. The point of this rig is to be out of sight behind the monitor, and be much cheaper and much more powerful than a Sager laptop, so I can't go against those principles. Also going to be running one or two virtual machines...
Any help you can offer me (even telling me it won't work) is greatly appreciate. Thanks again.
