1 - 3 of 3 Posts
Hello, I wonder if I could some advice on a graphics card upgrade. I currently have an HP Media Center PC model number m270n with these specifications:
Motherboard: ASUS P4SD with a uATX form factor, Pentium 4HT 2.8GHz
Video Card: GeForce FX 5200 with 128 MB memory, 8X AGP, with S-Video and DVI out
Power Supply:
Micro ATX-V200HP 200 Watts
Crude measurements of case size: Height: 14 inches, Width: 7.75 inches, Depth: 13 inches
I want to upgrade my power supply and Graphics card to these:
PNY GeForce 6800 GS / 256MB GDDR3 / AGP 8x / DVI / VGA / TV Out /
http://www.tigerdirect.com/applicati...Tab=0&NoMapp=0
KDM M6400/7400 400W MicroATX P4 12V Dual Fan Power Supply
http://www.directron.com/directron/m6400.html
Does anyone know if these will be acceptable with my current setup. I'm concerned about the following:
motherboard, which is uATX, and the graphics card says it must be compatiable with an ATX 2.0, is it?
graphics card size, I can't find the dimensions of that card but am concerned that it won't fit
power supply: will that power supply prove acceptable
Thanks very much for reading and answering
1 - 3 of 3 Posts
