I just bought this off a buddy it was a good price. I am trying to start a PC-Repair company. I cleaned out some dust and tried hooking other stuff up but im going to have to take it all apart to make it look really nice.
ANYWAY CPU-ID SAYS... and I think that the RAM that came with the computer are dual channel which I don't know if I can change that so I can add my other ram in or what. I have to upgrade to 64 BIT Windows 7 if I can do this.
CPU-ID Says
RAM Slot 1
-P/N (ocz2n800sr2g) 2048MB (2GB) 400MHz
RAM Slot 2
RAM Slot 3
-P/N (cm2x1024-6400) 1024MB (1GB) 400MHz
I want to add another 1 gig of corsair after I upgrade to 64 bit but with dual channel and stuff I don't if and what I can do. My one computer it would say 200MHz RAM but it doubled for some reason is how you calculate it. Right now I guess since my Windows is only 32 bit it says it has 3GB.
-Any help would be appreciated
CPU-ID Says
RAM Slot 1
RAM Slot 2
RAM Slot 3
