1 - 2 of 2 Posts
I have the M4E mobo and 16gb of Gskill 1600 ram. In CPUID my memory shows a DRAM freq. of 800mhz and a FSB:DRAM of 1:6. Is this ratio similar to a multiplier? Shouldnt my freq be 1600mhz? Maybe I need to adjust some settings in the bios? Help is appreciated
Stealth:ninja:
Your freq is running at 1600MHz. it shows 800MHz because it runs in dual channel, 800MHz in each channel to get the full 1600MHz. And yes the ratio is similar to a multiplier, it uses your cpu FSB which is why when you overclock your cpu with your FSB your ram freq increases also. Hope this helps. Nice rig
1 - 2 of 2 Posts
