Machine Lapping
509 Views 14 Replies 6 Participants Last post by  guyladouche
What machine should be used to lap processors and heat sinks?
1 - 15 of 15 Posts
A lapping machine.
That would be your strong hand and some elbow grease
These are the guys I buy from... http://www.easypckits.com/products/hslkwg/
Originally Posted by DuckieHo
A lapping machine.
They make those?!?!
I would assume you would use a lathe of some sort if you were going to get the top of the IHS machined. However lapping is much easier imo
Also, how much thermal resistance would be added if I copper plated some heat sinks?
Its like asking how much ohms will I be subtracting from a resistor if I put some really conductive wire before and after it... It won't change a thing, and if anything the tiny bit of thermal resistance the copper has will only bring worst performance.
What you want is lack of thermal resistance in a heatsink.
They make those?!?!
170 to 1200 grit for $280:
Why would you copper-plate copper?
-OR-
Why would you copper-plate nickel-plated copper?
-OR-
Why would you copper-plate aluminum and add an additional thermal layer?
For looks.
For looks.
Looks != Greater Performance
For looks.
Copper tarnishes....
Not if you lacquer it! Yeah! LACQUERED HSF FTW!!1
You should coat your HS in liquid nitrogen. It will get sub-zero temps!!!!
1337!!1
be careful with a lapping machine/electric sanders--you don't want to sand down to the die. Well, TO the die is fine, into it is bad...
1 - 15 of 15 Posts
