this will be updated as i get time and will only be updated from my nokia n810
the nokikia n series deviceses use the maemo operating systems which are 06, 07, 08. you can upgrade yor n800 to os 2008 if you choose to but you might loose a program that you need because you can not use 07 software on the 08 OS. and you can't install older OS's on new devices.
i will be talking about the n810 with OS 08
Size
* Volume: 128 cc
* Weight: 226 g
* Length: 72 mm
* Width: 128 mm
* Thickness: 14 mm
Display
* High-resolution 4.13" WVGA display (800 x 480 pixels) with up to 65,000 colors
Processor
* TI OMAP 2420, 400Mhz
Memory
* DDR RAM 128MB
* Flash 256MB
Storage
* Up to 2GB internal memory
* Support for compatible miniSD and microSD memory cards (with extender). Supports cards up to 8GB. (SD cards over 2GB must be SDHC compatible.)
Operating times*
* Battery: Nokia Battery BP-4L
* Continuous usage (display on, wireless LAN active): up to 4 hours
* Music playback: up to 10 hours
* Always online time: up to 5 days
* Standby time: up to 14 days
*Operating times may vary depending on the radio access technology used, configuration and usage. The availability of the product and its features depend on your area and service providers, so please contact them and your Nokia dealer for further information.
Other characteristics
* Smooth slide with integrated QWERTY keyboard
* Built-in GPS receiver
* High quality stereo speakers and sensitive microphone
* High-resolution widescreen display
* Integrated desk stand
* Integrated VGA web camera
* HW key to lock touch screen and keys
* Ambient light sensor
Connectivity
* WLAN standard: IEEE 802.11b/g
* Bluetooth specification v. 2.0 +EDR
o Profiles supported: HID, FTP, DUN, GAP, SPP, HSP, SAP and OPP
* USB 2.0 high speed
* 3.5 mm stereo headphone plug (Nokia AV
here are some pics of the N810
so i here you say what do all these specs mean
well the weight is good it feels solid but not to heavy to hold. the slider feels strong so i dont feel like it will break
the 800x480 screen means that you can view webpages at there full width
you can hook up to a wireless network
and with bluetooth you can use a bluetooth keyboard and you can use a phone as a modem
Saved For Size Comparison
Size
* Volume: 128 cc
* Weight: 226 g
* Length: 72 mm
* Width: 128 mm
* Thickness: 14 mm
Display
Processor
Memory
* DDR RAM 128MB
* Flash 256MB
Storage
Operating times*
Connectivity
