Preface: I am not building the computer today just trying to get an idea of what I need to look at in combo deals at newegg. Probably be buying after Intel releases their new i5 & i7 in September just to make sure that nothing earth shattering happens or prices drop a lot on the i7. Never had AMD before so do not know a ton about them. I do not really have a budget probably like to keep the motherboard & processor under $300 the less the better. I usually upgrade motherboard & processor & ram together, so I won't be upgrading on the board until I build another one in a 2-3 yrs.
Need (processor, motherboard, ram, cpu cooler):
PROCESSOR: Phenom II 955 Black (planning to overclock nothing drastic would like to get to 3.5-3.7)
MOTHERBOARD: My main question is on the motherboard. Would one of the following work or do I need something better. I only need one video card and want DDR3 Ram.
http://www.newegg.com/Product/Produc...name=AMD%20770
GIGABYTE GA-MA770T-UD3P AM3 AMD 770 ATX AMD Motherboard
or
MSI 770-C45 AM3 AMD 770 ATX AMD Motherboard - Retail
RAM:
http://www.newegg.com/Product/Produc...82E16820146871
mushkin XP 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model 996657 - Retail
Cooler:
http://www.newegg.com/Product/Produc...82E16835233029
XIGMATEK Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler - Retail
Thanks for the responses!
or
RAM:
Cooler:
