My thermal paste came in and tried to reapply it. Turned my comp on and went on for a sec and went off. I tried lookin if I put a lot of the paste and I did a bit and I have a tiny bit on the gold pin section. Any fix?!
I cleaned it off now using q-tip and a dab of alcohol. I'm scared to put it back on but mobo is still good with the LEDs on it for ram check, gfx etc. Any idea?
remover the battery which is there on ur motherboard and clear the bios.What typper of a HSF are u using ???
the methods to apply thermal paste and shown in the link below http://www.ehow.com/video_2200426_ap...pound-cpu.html
As long as you used 91% or better Ispropyl Alcohol and it left no residue, then you should be fine.
