1 - 5 of 5 Posts
I'm looking to upgrade the rig in my sig one last time before building a new one once K8L, K9, whatever comes out with AMD. I was thinking of getting a 165 opty and this ram<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16820227224" target="_blank">http://www.newegg.com/Product/Produc...82E16820227224</a><br />
I want to be able to overclock this thing to crazy speeds...Is this the best ram/cpu combo to get? I may also buy a second x1900xt for cf, i heard you can hack sli boards to run cf?
Reactions: Syrillian
<div>Originally Posted by <strong>Mootsfox</strong></div>
<div style="font-style:italic;">I'm looking to upgrade the rig in my sig one last time before building a new one once K8L, K9, whatever comes out with AMD. I was thinking of getting a 165 opty and this ram<br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16820227224" target="_blank">http://www.newegg.com/Product/Produc...82E16820227224</a><br>
I want to be able to overclock this thing to crazy speeds...Is this the best ram/cpu combo to get? I may also buy a second x1900xt for cf, i heard you can hack sli boards to run cf?</div>
</td>
</tr></table></div>
looks good but what type of power supply and case/CPU cooling are you going to have?
<div>Originally Posted by <strong>squwish</strong></div>
<div style="font-style:italic;">looks good but what type of power supply and case/CPU cooling are you going to have?</div>
</td>
</tr></table></div>
For a CPU cooler I'll probably grab a 9500 because it would work better than a BT in my case (probably). All the parts in my rig would stay the same except for the cpu and ram.
I TeK things...
meh...a 9500 and a BT will perform very close to each other...I suggest getting a higher CFM fan for it...then the BT will truley shine...mine has this on it....<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16811999127" target="_blank">http://www.newegg.com/Product/Produc...82E16811999127</a><br><br>
excellent ram BTW...
Discussion Starter #5
Opps, I meant the 9500 would do better in my case due to the way the air flows in it.
1 - 5 of 5 Posts
