hey guys im making a gaming pc and i wanna know if the "AMD A8 3850 APU" can run counter-strike 1.6 with a SOLID 100 fps (no video card just using the APU)
and i was wondering if i can using ANY ATI card to use the dual graphics with the apu
and theres a new amd cpu coming out called the bulldozer and is the bulldozer a APU or jsut a cpu? and can i use the bulldozer with this mobo - F1A75-M PRO http://www.asus.com/Motherboards/AMD...M1/F1A75M_PRO/ also if u look at specifications it say "Supports DVI with max. resolution 1920 x 1200 @ 60 Hz" does that mean my 120hz monitor (VG236HE) cant run in 120z?
and does anyone know any COOL looking amd cpu coolers for the AMD A8 3850
i only play maplestory and counter strike 1.6 so i dont think i need a video card if the apu does all the work
